Прошлая с завода 97 год арабская прошивка
вот выкладывая 96 год калифорния
Transmission Parameters
Min Force Motor %Duty Cycle 4,999 %D.C.
Drive 2 Mode 2->3 Shift Speed 256 MPH
Drive 2 Mode 3->2 Shift Speed 256 MPH
Drive Low Mode 2->3 Shift Speed 256 MPH
Drive Low Mode 3->2 Shift Speed 256 MPH
Torque Management Enable Coolant Temp -39,75 Deg. C
Kickdown Mode Enable TPS 93,8 %TPS
Kickdown Mode Disable TPS 88 %TPS
1st Gear Ratio 3,06 Ratio
2nd Gear Ratio 1,625 Ratio
3rd Gear Ratio 1 Ratio
4th Gear Ratio 0,7 Ratio
Reverse Gear Ratio 2,29 Ratio
Cold Transmission Disable Trans. Temp. 20,25 Deg. C
Cold Transmission Enable Trans. Temp. 17,25 Deg. C
Hot Transmission Enable Trans. Temp. 135 Deg. C
Hot Transmission Disable Trans. Temp. 126,75 Deg. C
TCC Enable Delay 0,01 Sec.
TCC Apply Ramp Delay 0,03 Sec.
TCC Maximum Duty Cycle 89,999 %D.C.
TCC Minimum Duty Cycle 0 %D.C.
TCC Downshift Off Time 1 Sec.
TCC Upshift Off Time 2 Sec.
